2 RF 12" HX2 subs and RF Power 800.2 (not as loud as they should be)
stocker08
Not drunk anymore
I just got these, the subs dont sound blown. They are wired so the amp should put out 800wrms x 1 bridged. The problem is, they sound weaker than my 2 10" Type E's connected to a 460 watt dual amp.
Does it sound like the gains are turned all the way down??? There are no bass boost knobs on the amp, ther is a plugin for a bass control, do i need that piece to turn it up.
Thanks for the help!
They are in a sealed box.
Here is the stuff i bought.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=017&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=270141577931&rd=1&rd=1
Update: I just connected another amp i have lying around, MA Audio M700XE ( http://www.sonicelectronix.com/item_6561_MA+Audio+M700XE.html ) which i believe is a little less powerful than the RF 800.2 and with the gain and bass boost turned halfway up, and the subs THUMP like crazy, so does it sound like i need to mess with the gain on the Rockford amp??
You're saying there is no gain knob whatsoever on the amp? Weird. If there isn't, but there is a spot for a remote bass knob, then you need the knob to adjust the gain. Don't use bass boost. It only adds distortion. If the box is correctly designed for the sub, you'll have a flat frequency response, so no bass boost should be needed.
What is the lowpass crossover set at? If it is set too low you won't get some of the bass.
your problem is your sealed enclosure....
Rockford Power HX2 subs ""****"" in sealed enclosures
they need a ported enclosure
if they are the punch HX2's you need 2.0cf3 per sub plus
sub and port dissplacement
and if they are the power HX2's you need 2.5cf3 per sub plus
sub and port dissplacement....
I would tune them around 34-35hz and give each sub no less
than 26sq inches of port area
alright....i turned the gains up using a very small screwdriver and it sounds much louder. I still think I need the Bass Control knob so i can add Bass Boost.
Or you could just upgrade to a rf power 1500bd that i jsut so happen to have lying around //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif...that i could get rid of you know......thats just my opinion though;)
stocker08
Not drunk anymore
stocker08
Minnesota
stocker08
