(2) RE Audio 10" SX's in a 4th order bandpass ported through the rear deck of a Lexus
Any plans to make a beauty panel to enclose the box into the front of the trunk and mount/show off the amp? I really like the build, but being a lexus and the box having black tape are a little contradicting //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif Although I'm sure you've got plans to tidy it up a bit //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Any plans to make a beauty panel to enclose the box into the front of the trunk and mount/show off the amp? I really like the build, but being a lexus and the box having black tape are a little contradicting //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif Although I'm sure you've got plans to tidy it up a bit :lol:
lol about the tape, it's just temp. The trunk is unfinished.... Haven't had time to make a flush cover for it yet. The cover will strech across the entire length of the box, it will be carpeted in the same color as the trunk carpet and hide the box and the gaps to the left and right of it. I also plan to make a false floor for the amp to flush mount it under plexiglass with a couple 80mm pc fans for cooling. I might flush mount the batter but it would require me to remove my spare tire. With the amp flush I can throw the Lexus rug over it and you wouldn't see a system in my trunk, it would just look like a smaller stock trunk.
I was thinking about doing a false floor too to mount my amp and I was concerned about the heat buildup so I thought about computer fans. My question is, how would you wire those up? Would you just run a couple more remote 12V switch leads from the head unit that tells the amp to turn on? Does that put out enough current to run those fans? How are you going about doing that, I'd like to do that myself //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
For the 12v pc fans you can use the remote wire to tell them to turn on. They have (3) wire pc fans too.
yea just jump off your amps remote terminal for power or crossover etc. same with ground. i use a 2 wire one. works great. just watch cuz some will cause a whine in your system.
SHiZNiLTi
SHiZNiLTi
Scottsdale, AZ
MiX
