SOLD 2 power bas 2xl-10D's $145 plus shipping
dbeez
crestwood,ky
They are dual 4 ohm..
Box Specs 2XL-10D
Optimum Sealed Vol.
Standard
Metric
Gross Vb Internal
0.5 cu. ft
14.15 Liters
F3 (-3dB Cutoff)
57 Hz
57 Hz
Poly-Fill
Yes
Yes
Qtc
.716
.716
Pe (Watts-Rms)
100 - 400 Watts
100 - 400 Watts
Acceptable Volumes
(0.45 - 0.75 cu. ft)
(12.74 - 21.24 Liters)
Optimum Ported Vol.
Standard
Metric
Gross Vb Internal
1.0 cu. ft
28.32 Liters
Circular Port
3" x 9.9" D
7.62cm x 25.15cm D
Fb (Box Tuning)
40 Hz
40 Hz
F3 (-3dB Cutoff)
36 Hz
36 Hz
Pe (Watts-Rms)
100 - 300 Watts
100 - 300 Watts
Subsonic Filter Setting If Applicable
36 Hz
36 Hz
If only they were d2's. I'm looking for some better 10"s for my gf...Free BUMP for you.
Sorry to get off topic, but do you have any more of that 1/0 Monster left?
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
501
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
713
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
530
dbeez
dbeez
crestwood,ky
dbeez
