2 ohm vs. .5 ohm mono
Theoretically, 3000w @ half an ohm would draw less current because there is less resistance, therefore the amp would have to 'work' less in order to produce the power.
But it is dependant on the amplifier, every amp varies with efficientcy.
No. Ohms Law man. Think about it. Resistance is the resistance to current flow. Less resistance means more current.
Not true.
Amplifiers will decrease in efficiency as the load decreases. More current + more stress on the components in the amplifier are going to lower efficiency. Here's a good example. PG Xenon makes roughly equal power into 4ohm, 2ohm and 1ohm....yet look what happens to the efficiency (towards the bottom of the page). Under your theory, efficiency should increase as load decreases;
http://carsound.com/articles/publish/article_413.shtml
As was mentioned....you would have to compare the specific amplifiers in question. But I would be genuinely surprised if the amplifier operating at .5ohm would be the more efficient amplifier.
i feel squeak typing......
Did you get a tingling sensation in "your special place" //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
Not true.
i knew it.....
HEYYYYY....mom said never discuss the "special" place with people outside the family
so would i be better off at 2 ohms if my charging system isnt above 200 amps.i see everyone running at .5 and .7 daily but that has to kill batteries.reason im asking is the hk4000d runs at 2 ohms stable but i've seen modded to do .5. is this necessary or will 2 ohm work? im looking for spl not sq.if i need a mod anyone have any recommendations??
Can you run them on 1 ohm daily?
audioarsonal
JaMarcus
audioarsonal
close to home...
audioarsonal
