2 ohm load w/ 2 ED12K's????
ngsm13
BSEE
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
is there any way to get a 2ohm load with 2 ED12k's. Either the dvc4ohm models or the dvc2ohm models......doesn't matter. Can i get a 2ohm load w/ either of them using 2 speakers???????????
thanx
get the dual 2 ohms'....
wire them in parallel series
each sub becomes a 1 ohm laod when wired to itself in parallel, and then wire the subs together in series to make it a 2 ohm load!
let me know if you need a wiring diagram
k,
sub 1 -> run a wrie from teh pos. on one coil to the neg on the other coil.
sub 2 -> do the same....
now, from your amp, run a wire from the positive terminal to the positives on the remaining coils....
negative terminal - run to the negatives on the remaining (unused) terminals...
ngsm13
BSEE
ngsm13
Cincinnati, OH
ngsm13
