Sold 2 nightshade 15s l db louder
justadork2u
i have pair of nightshade 15s dual 1 ohm Jake did something different with these the are a db louder than others the surround is oversized therefore they have to be bare back lol no rubber i taped em in but they wouldnt look as bad with strip caulk anyway i found something that i really want and need to sell the quik so 425.00 shipped pair or 250.00 shipped each
i have pair of nightshade 15s dual 1 ohm Jake did something different with these the are a fulll db louder than others the surround is oversized therefore they have to be bare back lol no rubber i taped em in but they wouldnt look as bad with strip caulk anyway i found something that i really want and need to sell the quik so 425.00 shipped pair or 250.00 shipped each
lol. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
great price regardless.
l would think that these woofers will differ but heres the specs for stock ones
•Dual 2-ohm or Dual 1-ohm Voice Coils Available
•3" Diameter 8-layer flat-wound Aluminum Wire Voice Coil
•High Temperature Aluminum Voice Coil Former
•1500-Watts RMS Power Handling
•Over 2 inches peak to peak excursion
•Wide, triple-layer foam surrounds for high excursion
•Extremely strong paper cones w/ stiffening disc
•Thick poly dust caps
•Cast Aluminum 12-spoke basket with cooling vents
•Triple Stacked 1" x 9" magnet slugs for high motor strength
•MSRP - $629 USD
T/S D1 **:
RMS: 1500
Z: 2 ?
Re: 1.44 ?
Fs: 43 Hz
Qms: 6.83
Qes: 0.43
Qts: 0.40
VAS: 11.7 L
BL: 17.6
Those two were mine at one point, did some testing and R&D with them -- they were the first two with the "vented" voice coil formers, which gained about 0.4 dB for me...
They also have a lighter cone, a slightly less stiff spider pack, slightly softer surround, and no stiffening disc under the cap (less mass)... overall around a dB louder in my box than a regular stock model.
They are ugly but loud //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
justadork2u
justadork2u
mooresville nc
justadork2u
