Taramps HD 8000 - 1 Ohm
Specs:
Number of Channels:
Power 13.8 VDC - 1 ohm:
9595W RMS
Power 13.8 VDC - 2 ohm:
6305W RMS
Power 13.8 VDC - 4 ohm:
3646W RMS
Power 12.6 VDC - 1 ohm:
8000W RMS
Power 12.6 VDC - 2 ohm:
5256W RMS
Power 12.6 VDC - 4 ohm:
3040W RMS
Input Sensitivity:
250mV @ (-9.78 dBm)
Total Harmonic Distortion ( THD):
0.3%
Frequency Response:
10Hz to 15KHz
Crossover:
HPF (High Pass Filter):
10Hz to 50Hz (-12dB / 8th) Variable
LPF (Low Pass Filter):
50Hz to 15KHz (-12dB / 8th) Variable
Bass Boost:
0-10 dB (50Hz)
Input Impedance:
18K OHMS
System Protection:
Short on Output Voltage / High Power / Low
Voltage Low Power:
10.5 VDC
Voltage Maximum Supply:
16VDC
Consumption at Rest:
2.50 Amp
Maximal Musical @ 12.6 VDC:
412 Amp
Maximum Consumption in sinusoidal signal (1kHz) @ 12.6 VDC:
826 Amp
Dimensions (WxHxD):
229 X 65 X 497mm
Weight:
6.11 kg
. Description/Condition:
new as in never used mounted or tested simply opened the box, they still have factory protective film on amps .
i bought these for testing but due to delay arrival i ran out of time and went with different amps . . i bought these from an authorized dealer so if there is a warranty issue i was told he would take care of it.
750 each shipped 1 amp sold 1 is still for sale
free con u.s.
pics
http://i1148.photobucket.com/albums/o568/calp1258/018_zps6tmxlxfx.jpg
http://i1148.photobucket.com/albums/o568/calp1258/019_zpsp7jfbfby.jpg
http://i1148.photobucket.com/albums/o568/calp1258/022_zpszrqghjf0.jpg
Specs:
Number of Channels:
9595W RMS
6305W RMS
3646W RMS
8000W RMS
5256W RMS
3040W RMS
Input Sensitivity:
250mV @ (-9.78 dBm)
0.3%
Frequency Response:
10Hz to 15KHz
Crossover:
Bass Boost:
0-10 dB (50Hz)
Input Impedance:
18K OHMS
System Protection:
Voltage Low Power:
10.5 VDC
16VDC
2.50 Amp
412 Amp
826 Amp
Dimensions (WxHxD):
229 X 65 X 497mm
Weight:
6.11 kg
free con u.s.
pics
