Sold 2 new sets of digital designs cx5.2 coaxials
loudmofo
1. Product: 2 sets of dd cx 5.2 coaxials
2. Specs:
DDCX5.2
The new CX series of coaxials are improved over their predecessors in many ways. The cones and dust caps are now lighter and stronger by way of injection molding and incorporates 101 trace minerals that prolong healthy life (not tested or proven by the FDA). These minerals help to support healthy bones and light amounts of fish oil help fight osteoporosis. They use a much larger diameter motor for increased output on the same input power and higher overall power handling. Every model utilizes an aluminum voice coil former for higher long-term power handling. The suspension is slightly stiffer to handle the extra motor force.
The tweeter utilizes a larger neodymium magnet than before, improved rear chamber venting and braided tinsel leads as well as an upgraded film capacitor. The new CX coaxials are really component sets with an integrated, swivel, high-end tweeter.
The CX line now brings separate component sound quality to the harder-to-fit applications.
| Mounting Info | Enclosure Info |
SPECIFICATIONS
Series
CX
Nominal Impedance
4.0 Ohm
DC Resistance
3.1 Ohm
Model
CX4
CX5.2
CX5x7
CX6.5
CX6x9
Woofer Diameter
4"
5.2"
5"x7"
6.5"
6"x9"
Voice Coil Diameter
1"
1.25"
1.5"
1.5"
1.5"
Magnet Weight
12 oz
14 oz
16 oz
16 oz
16 oz
RMS/Music/Peak
50/80/160
60/100/200
80/120/240
80/120/240
80/120/240
Frequency Range
70 Hz - 22 kHz
60 Hz - 22 kHz
50 Hz - 22 kHz
50 Hz - 22 kHz
40 Hz - 22 kHz
Sensitivity
88 dB
89 dB
91 dB
91 dB
92 dB
Shipping Weight
5 lbs
7 lbs
10 lbs
10 lbs
10 lbs
3. Description/Condion :
new never used
4. Price: :
$75 shipped each set
5. Pictures:
Once in a while you come across a good deal on something you have never tried out before, and REALLY want to... but realize you are too broke to even consider it, nor do you have a car they can really be used in..... That is me right now. If the right trade was considered, I would snag these. But you probably don't need anything I have, and I don't have a car for them...
To sum it up: I want, can't have, free bump. //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
loudmofo
loudmofo
Providence, Rhode Island, United States
loudmofo
