2 MTX MZS 1204 in ported box, want better sound help!!!
StreetGlo_RSX
hey everyone, i purchased 2 12' MTX AUDIO MZS 1204 subwoofers and an MTX 6001 mono block d class amp to run it. Im running four gauge wiring and a ported box. First of all sum ppl say it hits hard. BUt i want it to hit Harder im wondering if i change the box will that amke a difference? Or if i possibly change some wiring or something. Sumone Help. Also wat would u guys rate the subs i bought if u have ever heard them?
Second Question , I get a lot of rattling, if i dynomat my trunk will it make a huge difference?
Thnx Alot
StreetGlo_RSX
What size enclosure do you have right now? What is it tuned to?
I'd go with about 2.0ft^3 per sub if you want to go ported.
I'd start with tweaking your head unit and amplifier, though. That's free, and can sometimes make a world of difference. Stay away from the bass boost and be careful with the gains, however.
They're definitely not my favourite driver, and I do believe there are better ones out there for the money.
Just please don't tell me you paid $199.99 per sub ... because then you really could've gotten much better for the money.
Oh, and yes, sound dampening will help the rattles and road noise.
- Steve
Use second skin, fat mat, Peal and seal (if you live in colder areas), eDead... don't use dynamat. mtx's are okay subs... They're more spl than sq but not that good. Wire is wire is wire... Lower gauge wire does support heavier loads but other than that it's all the same.. no noticible difference. Anyways, good luck with all that
I didint pay $199 per sub. I actually got both for $199 i thought it was a good deal for the price but thnaks for ur guys help.
It's a decent deal ...
A whole hell of a lot better than $199 per sub.
- Steve
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
709
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
StreetGlo_RSX
StreetGlo_RSX
Toronto
ss3079
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
