(2) Mono Block Wiring Help!
I am about to set-up (2) MTX T9510-44 Series Subs and I am powering them with (2) Mono block Pioneer GM-D510M amps. I was just curious, how I would be able to wire them. I also am putting a 4-Channel amp to power my components and 2-ways. But my HU only has 3 pre-amp outputs. Would this set up be able to work at all? Thanks.
The two sub amps would need to be daisy chained I believe, that way the proper signal could be sent to both. The comp amp would either be wired with the front or rear out, I would chose front if it has only one set of RCA in.
For wiring the amps, you will need to ensure you have proper sized wire coming from the battery, and then split the wire at a distro block. Ensure proper fusing for proper wire size.
jaden_fackrell
jaden_fackrell
Salt Lake City, UT
squeak9798
Mike Mccabe
