M mccoy 10+ year member Member 38 0 pikeville, ky Nov 29, 2008 #1 i need box specs. i looked on jlaudio.com...but would the cu.ft be different for vented? would a box off ebay sound good? Click to read more...
T tez4life Premium Member Premium Member 4,037 1 Mobile, Al Nov 29, 2008 #2 Did you check here, http://mobile.jlaudio.com/pdfs/15_18W6_BDS.pdf And yes its going to be different from sealed to vented, almost always required a larger enclosure when you go ported. And no, save your money, and contact one of the box builders on this forum. You will be much happier with the results.
RAM_Designs 5,000+ posts SketchUp Master 21,735 362 Rockwall, TX Nov 29, 2008 #3 I'd do about 3ft^3 each tuned to 33-35hz.
OP M mccoy 10+ year member Member 38 0 pikeville, ky Nov 29, 2008 Thread Starter #4 thanks..now i can get sum designs
