2 different sized 4 ga wires
bmk6795
Ok heres my situation, it takes about 13 ft of wire to run from my batt to my my trunk. I have some no name brand 4 gauge wire that i was using for my sub amp. I got a 4 channel so i ordered a knu 4 ga kit and and now gonna be using the knu for my sub amp. When i installed my 4 channel i installed it up front so i cut a couple feet off of the wire, is it ok to take about 2 ft of the knu and solder it to the other 4 gauge and run it to the 4 channel? Gonna be moving the 4 chan to the back so im gonna need a couple extra feet. I dont have the piece that i cut anymore so im hoping this will be ok.
Probably not a good idea as you're creating a choke point where the wires are joined. This could cause extra heat buildup there which is something you should try to avoid. Since you have a full Knu kit, take the extra time to re-route their 4ga and you should be much better off. Knu is beefy wire and tends to exceed AWG standards. Also, the no-name stuff probably doesn't adhere to the same standards, hence why there's a difference in the size.
Need more info about your amps as in how much power they make/current draw. But without knowing that info I'm gonna say the Knu 4 is probably good enough to run both amps and you can just pick up a distro. Or if your set on running the extra wire and it's going to be on the 4-chan, the splice should be fine as long as you insulate the crap out of it. You might also consider buying a 4 guage splice terminal. They're only $5.
bmk6795
bmk6795
Spartanburg, SC
Snapper_Slapper
