2- dd m4a's in nice shape
dbeez
Item(s) for Sale: 2-dd m4a's
Item(s) Description/Condition: good condition slightly used
Bridged
NA
Channels
Cont Power at 1 Ohm
5200W x 1 @ 12v
Cont Power at 2 Ohm
NA
Cont Power at 4 Ohm
NA
Damping Factor
>150
Dimensions (Inches)
27.625L x 9.13W x 2.5H
Dimensions (Metric)
702L x 232W x 63.5H
Dynamic Power
9500W
Efficiency Thru Output
87%
Input Sensitivity
0.15v - 5v
Shipping Weight
36 lbs
S/N Ratio
>100dB
Tested THD
≥1%
Tested Voltage
12v -14v
Variable Bass Boost
0-6dB @ 45Hz
Variable High Pass Filter
NA
Variable Low Pass Filter
20Hz - 200Hz @ 24dB/Oct
The M4a, with its 6 transformer power supply, is our next generation mono-block, building on the M3 and Z2-LV circuits. The M4a was designed to be the best tool for hard street use, extracting extremely high power from real-world battery supply voltage and the ability to maintain that power for extended periods. The M4a delivers over 5000 Watts of SQ quality RMS power at 12 V,over 7000 Watts of continuous RMS power at alternator charging levels and dynamic power over 9500 Watts.
The M Class heatsink makes installing such a monster amp as easy as possible with a 9 inch width as oppossed to the surfboard sized amps normally found in this power class
$1250 shipped ea. In conus
Included in price
Item Pictures: will have these tomorrow many many refs.
dbeez
dbeez
crestwood,ky
dbeez
