2 cvr 12 ported
Acer9876
20
Tx
built a box for 2 cvr 12s. dual 4 ohm. about 1.5 ft air each, and tuned around 40.
i know its a lil high. but thats not the problem. i have them pluged into the amp. and when musics playing they arent really fleving to the beat. theyre more of..... vibrating...? really fast.
and then i turned the truck off. turned it back on with volume all the way down. and sequentially they were bumping left to right. it sounded as if they were going with the cylinders of the engine.?
and theyre on a q power 1800.
please help. its really bothering me
you have a noise/grounding issue..
make sure you have a good ground to your amp..
and yea you might have the rcas grounded, like said above check make sure that they aren't grounded..
also FYI the wire inbetween the rcas isn't a ground it's a drain, only use it if you have notice like alt whine etc.. also you only ground one side..
Acer9876
Acer9876
Tx
Papermaker85
