2 Channel Amp
  • 4
Hades2004
Underworld Master
279
Canada
I'm looking for a 2 channel amp for my SPR-176A. I'm looking for an amp that does 60-80 watts RMS. Would amp would you recommened? Or should I get a 4 channel amp and amp my SPR-694A too? Also somehwhere between 60 and 80 watts RMS.
Opps. I guess this would help. 60-80 watts RMS to each channel. I was looking at the Alpine MRP-T220 which does 50 watts RMSx2 @ 4 ohms. But should I just spend the extra $50 to $80 on a 4 channel amp and amp all my speakers?. Anywhere from 60-80 watts RMSx4 @ 4 ohms will be fine. Thanks.
spend the extra and get a 4 channel.
did you see any that you might be intrested in?
post some brands and model numbers, so
we can all try to help you out
For a 2 channel amp I was looking at the Alpine MRP-T220, and the 4 channel amp MRP-F240. For Rockford 2 channel the P3002 and for the 4 channel P4004. I really don't need that expensive of an amp for my speakers tho. I showed my uncle my stuff and he said that my Head Unit which is the CDA-9833 will give my speaker distorstion. So he recommened that I got an amp for my speakers.
I was looking around and I was looking at Phoenix Gold. I came across this amp by PG, the OCTANE-R 5.0:4. It's $160 at Woofers Etc. Would this be a good 4 channel amp for my speakers? It does 80 watts RMSx4 @ 4 ohms.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
425
6
498
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
873
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
904
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Hades2004
Underworld Master
Hades2004
Canada
Hades2004
