2 Cerwin Vega V-Max 10 inch dual 2 ohm versions
cleansoundzz
V-MAX series subwoofers, like the VMAX102, has been the most popular, award-winning, series of Cerwin-Vega subwoofers for the last 10 years for many reasons. The series of subwoofers are offered in a 10", 12", and 15" size with each respective size having the option of a Dual 2 ohm or Dual 4 ohm voice coil. They offer a power rating of 1000 watts peak and 500 watts of continuous RMS power making them your daily "ground-pounders". With these many different sizes and impedance options, these woofers offer versatility and a significant amount of bass that is sure to fit anyone's bass needs. The woofers feature a composite polypropylene cone and a wider larger than normal rubber surround for increased excursion level, performance, quality, and strength. The use of O2 Cast technology increases basket strength and lowers basket resonance, which also increases the quality and performance of the subwoofers. The woofers also feature cross-flow window venting that reduces voice coil temperatures and radial contact convex domes that reduce cone flex and minimize distortion. If you want to achieve exceptional low-frequency reproduction that is accompanied by quality manufacturing and amazing value, look no further than the Cerwin-Vega VMAX series subwoofers.
10" Dual 2 Ohm VMAX Series Subwoofer
Power Handling:
Peak: 1000 watts
RMS: 500 watts
Impedance: Dual 2 ohm
Polypropylene composite cone woofer for the perfect weight to strength ratio
Wide rubber surround
Radial contact convex domes design minimizes cone flex and reduces distortion
Window framed venting draws cool air directly to the voice coil for increased power handling
Dual linear rolled spiders for unmatched assembly cone control at all volumes
2.5" Dual 2 ohm high-grade voice coils
O2 Cast technology increases basket strength while lowering basket resonance for increased performance and quality
Sensitivity: 83.1 dB
Cutout Dimensions: 9-1/4"
Mounting Depth: 6-3/8"
1-year Manufacture's warranty
Purchased brand new from dealer, used for 1 month, then stored in the shed for 3 years in boxes. 9/5 out of 10 condition.
$160 shipped for both woofers anywhere in the United States
cleansoundzz
cleansoundzz
Buena Park
cleansoundzz
