(2) cactus 5ks for $750 shipped ea
daddy_j
Two cactus 5k amps
Team Cactus 5kw
Actual test specifications
Number of channels
RMS Power 1 Ohm
( 12.0V )
3400W
RMS Power 1 Ohm
( 14.4V )
5000W
RMS Power 1 Ohm
( 16.0V )
5900W
RMS Power 1 Ohm
( 18.0V )
7500W
2pcs linked RMS Power 2 Ohm
( 14.4V )
9900W
RMS Power 2 Ohm
( 16.0V )
11900W
RMS Power 2 Ohm
( 18.0V )
14900W
THD
Input sensitivity
0.2 - 6 V
Lowpass filter
30 - 300 Hz
Subsonic filter
10 - 60 Hz
Phase control
0 - 180 degrees
Remote level control
Yes
Two amp linkable function (Output Master/Input Slave)
Yes
2 x 0 Gauge power supply connectors
Yes
Line output
Yes
Dimensions ( W x H x L )
for FA & FAB
270 x 65 x 620 mm
$750 ea
They are coming from San Antonio 78222
if that was for both i'd buy them
I don't want to get in a war with you, but are you stupid? With all the Louisiana records I'd think you had more sense than that. The cactus pf600s go for more than that, used.
before this gets ugly, $750 for an amp that can do 7500 watts on 18volts @1ohm easy is not a bad deal. I haven't seen many deals like this on the site. This amp can be dropped down to .167 if you have plenty of battery power. In my vehicle 2 of these 5ks were louder than 2 rd d9s by .4dbs.
Only reason I am selling them in because I run SS600-1800 and I can only use one, so Im trying to buy 3 cactus pf600s.
only trades are for cactus pf600s, if your lucky you can find one used for $600, but no one sells them once they have them. I was offered $850 if I wait till the middle of Feb. If it get closer to that date, I'll just wait and sell them to him.
I'm trying to get my new PF600s before Spring Break and that's like ~30 days away. And its gonna take like 3 weeks once I pay for them, to come in.
i want to upgrade my system to 2 or 4 btl 18".... right now all i got is stock alt, (2) 800cc batts, 50 farad stinger cap, hifonics 2600 , pushin (2) l7 15"s(11cubes slot ported 35hz) @ 1ohm..... my **** is loud and dont dim lights, but its sloppy as hell, i want some super duper DUPER bang, with alil more accuracy. if i buy these cactus 5ks how many rms could i really put at the btls a piece(could i do 5k to each) ?? ...i know ill have to upgrade big time on electrical too. ...plz lemme know (i have a 2002 denali) thank u thank u
real world they will do 5k per amp at 1 ohm ~13volts, but at .25 you'll get close to 6500 watts at 13 volts. These would be better on 4 btl 18s, if daily, or 2 btls for straight burp. Daily these would kill two btls. but it all depends on your final impedance.
i dont know anything bout cactus, but to be safe i guess id run them at 1ohm. how low can they go safley for daily?(i suppose there's strict elecrical required) What kind of fusing will each need 500a?
I don't run fuses, but the site says 500amp fuse. 1ohm daily is fine and strapped at 1 ohm, where each amp sees .5 is ok. Have at least 2 batts per amp, and an HO alt. If you don't have extra electrical, keep them above 4ohms.
that's fine but the price is $750 per amp, with that $1200 go buy that AB500.1 or SAZ4500
I don't think anywhere on my post did I put OBO, the price is there, if you want them come up with $1500, if not go buy 1 AB500.1 or 1 SAZ4500, sure you'll end up with only half the power, but if thats all you can afford.......
daddy_j
daddy_j
san antonio, tx
audioholic
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
