Sold 2 BNIB Orion Hcca 12.2 's
sound_around
Banned
1. Product: 2 BNIB Orion Hcca 12.2's
2. Specs:
3. Description/Condition:
BNIB one was opened for pics and to hook to a woofer tester to pull full specs, the other is still sealed from Orion.
4. Price: :$300 each + shipping or the pair for $675 shipped
if you are close we can go a little cheaper by saving on shipping.
prices are OBO so make offers
5. Pictures:
phill,thanks for the VERY educated post....i know your the man //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif now come test BOTH my astro's!
you know im no dummy here and as far as my comment about the Hcca's killing the Fi's goes,i have seen no BTL take what these have done over,and over,and over again.
anybody want to burp 2 BTL 12's on four memphis 4Kw's many times a day?thats 4000RMS or more per COIL....
ttt
ok good luck to that person..and i didnt say for sound wise i was talking about safety wise(well for sub atleast
Please Note: Due to the extremely long excursion and high temperature possibilitiesof this woofer, it is recommended that when the woofer is installed it be positioned
so that the cone either faces upward or downward only.
that comes from the 2007 manual....which is the new model.
they also said that they wouldnt do over a 148db.directed doesnt know their azz from a hole in the ground.believe the hype if you want but it makes you look just as stoopid...//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Remember folks, this is without any prior break-in!
These parameters are from the sub i spec'd. Which is one of these drivers, Orions (Directed's) specs are way off on these in quite a few areas, I tested the old ones broken in and the only real difference was a slight drop in FS, they ended up resting at 38ish Hz and the Vas climbed a lil so the sensitivity stayed pretty much the same. 83.23dB on the old ones, 1w/1m. The BL on these is higher than the older models had. The olders were 22TM in series.
sound_around
the hills
sound_around
