2 Big Amps
MikeNeufeld
In a real world setup, how will these matchup against each other
massive audio p3000.1 ------------ vs-------------------Earthquake Ph5000d
speaking in terms of actual output, cleaner signal, amp draw, reliability and qaulity for running 4 12's in a multi sub configuration...... need to know asap...
they both have very similar power output. personally i would buy the massive out of those two, or what ever is cheaper.//content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
anyone on here use any of these amps at this moment and can give me some unbiased opionions as to why they chose what they are using or anyone who has any exp with these amps....
i have the earthauqake phd 10000 which is the same just you can strap it. it puts out good power while not pulling alot of amps. Make sure you have a decent charging system though because if you dont the amp will clip like crazy and kill your subs. It did it to my DD.
I have the Massive and couldn't be any happier. I hear EQ is also lacking on thier build quality, not what they used to be, but who is anymore? My p3000.1 has never overheated on me but it does get hot, and that's after VERY long hours with the music just cranked up. I do have two yellow tops feeding it though. I'm sure whichever one you go with, you will be happy. At this point, it comes down to size and looks. If available space is an issue, get the EQ, since the Massive is 34 inches long, IIRC. If you are more interested in the looks, get the Massive because I think it looks sexier than the EQ.
do both these amps also do near rated power and do they come with birthsheets...... just curious...
the birthsheet really should not be an issue when buying. real world actual power is
determined by voltage, rise etc.........i may be biased but why not a kicker 2500, i
think they can be had for around the same price and we all know that is a proven
well built amp.
MikeNeufeld
MikeNeufeld
VanCity
bigpetey
BP1Fanatic
BP1Fanatic
