2 Amps...wantiing to power 1-12" Subwoofer
I have 2 amps...a "Boss CX450 600 Watt 2-Channel Amp"...and a "Pyle PLA2378 2-Channel 2,000-Watt Bridgeable Mosfet Amplifier".
I'm wanting to know which one should I use to best push 1-12" subwoofer in the trunk of my car.
Also, what would be the best 12" subwoofer I should use?
All I want is some good hard hitting clear bass!
Thanks guys, hope I get some help!!
first things first those amps dont do rated power neither is a good option but since you have both go with the one tthat has the bigger fuses and bridge it , if you wantt real power i have a mono amp better suited for yoour needs $100 shipped
based on fuse rating, pyle will do around 300 watts rms and boss will do 250 watts rms but... its boss and pyle.... so if your lucky, they will do around half of those numbers. Might as well sell both and start with a monoblock amp to be honest. Neither are gonna push any subwoofer well.
those are only 300 watts rms ttrue power on their best day i can step you up to abot 700-800 rms mono power ment for subs only and youll be slammin, as for the sub just match the rms rating there arre alot of subs out tthere its all your preference really any sub will slam just have to have the right box built not one you can buy from a store they are wastes of money unless its just temporary
Cajun Ricky
Cajun Ricky
Cartersville, Ga
Nutdawg651
