right now i have a 1500 watt audiopipe stable 1 ohm hooked up to 2 l7s now should i buy another amp and put one amp on each speaker? how i go about doing this
look all you need is a mono amp thats either 1ohm stable or one that 2 ohms stable. reason why! well if you have a 2ohm stable amp the you can series wire them up to get a 2ohm load, if you get a 1ohm load you can parallel wire them up (parallel is hoooking all positives together and all negatives together )whats your budget by the way??
