2 amps(non-strappable) - three subs
kowboy
I've got an autotek mm4000 (2000 x 2 @ 1ohm). And I wanna buy an autotek mm2000 (2000 x 1 @ 1ohm).
I have three subs sharing a common chamber(dual 2's). The mm4000 is just two mm2000's in one case if I'm not mistaken.
So...basically I'd have three channels each running 2K @ 1 ohm to each sub. Is this do-able? How would I match the gains (very carefully, lol!)?
Is this gonna be more trouble than it's worth? 'Cause it's the most economical solution for me to get 6K watts since I already have the mm4000.
What do u guys think? Bad idea? Or perfect for my setup? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
If your setting it up for burps, it would be pretty simple to do. set your voltage at your burp frequency. If setting it up for daily , I would be a bit more checking a wide variety of tones that closely matches what you usually listen to.
and theres a good chance it will cause problems, with the amps not strapped, the gains cant be quite exact, with them all in a common chamber, with some receiving different voltages, you may suffer from some issues..
if you do go through with it, Id at least make seperate chambers
I have to agree, they really need to be in seperate chambers if not your destined for phase issues.
i have a mm4000.1 goin up for sale in a few days
(just dont have time yet to pull it out and take pics)
If they were strappable, my problem would be solved! Love the amp btw. Mine is bulletproof!//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
kowboy
kowboy
The "D"
kowboy
