1wheel_drive
CarAudio.com Newbie
Hi everyone!
I'm new to the forum, so let me apologize in advance for any newbie mistakes or inadvertent blunders.
I've been working to put my sound system together, and I can definitely use some help from those who are more competent than I am (probably most of you!)
A bit of background:
I bought my 2008 Audi TT coupe secondhand. The original owner was in the army and had purchased the car in Germany. He then brought it to the US, drove it, and traded it to an Audi dealership.
During the CPO process, the dealership removed most of the aftermarket stereo stuff and kindly put in a large cardboard box. They then installed the original Audi head unit. The speakers were left in place, but several of them were never connected. The amps were removed, as was the aftermarket head unit.
My goal:
I'm now looking to reinstall the 2 amps (details lower), reconnect all the speakers and replace the factory head unit with an Audi RNS-E Nav unit (details below).
My gear:
Head Unit:
I'm using an Audi TT RNS-E upgraded unit (part 8J0 035 193 F). It's much better than the standard Symphony/Concert system that TTs come with and it integrates perfectly into the console. I know there are better head units out there, but I'd like to try and work with the head unit I have.
Amps:
I have 2 identical 4-channel amps. I disassembled them, had the housings blasted and ceramic coated, and then assembled them back.
They are made by u-Dimension. It's an uncommon brand in the US, as far as I can tell, but since the car was purchased in Germany, that's what the first owner had put in. I looks like decent stuff. Please correct me if I'm wrong.
Speakers:
The car has 9 speakers total. They are also made by u-Dimension and seem to be solid.
A bass and a mid in each of the front doors - 4
A tweeter on either side of the dash - 2
A center speaker on the dash - 1
Rear speakers behind driver and passenger - 2
I'm not sure whether the rear speakers are mids or bass, as I haven't removed the panel to check yet.
Wiring:
There are wires running to all of the door speakers, but the speakers don't work. I'm thinking it's because of the way the wires were cut at the harness, when the aftermarket stereo was removed and replaced by the factory one.
The other speakers work fine.
My battery is in the trunk and I'll be mounting the amps on the back of the rear seats in the trunk area (so pretty close to power).
Questions:
Now for the fun stuff!
1) The RNS-E head-unit does not have RCA outputs but it does have pin-outs for 4 channels (FR, FL, RR, RL). There seems to be a way to get signal from them, by creating a PIN-to-RCA harness (as described here). But the question remains, which set of outputs should go to which amp?
2) The second question is which amp to use for which speakers. Originally, one of the amps had stickers for Subs and Rears. The other didn't have stickers, but I'm guessing it was for mids and tweeters. I need to know which amp to use for which speakers.
3) How do I go about getting the signal for the center channel. The head-unit doesn't have a specific output for that. Should I get it by bridging the mids?
4) Do the amps need to be connected between each other? If so...how?
5) Do you think I should use the existing wires for the speakers or try to run new ones? I'd like to avoid running new wires, especially if the car was already wired before. That being said, I have several of the panels off, the carpet is halfway up and I'll need to run a remote-on wire and a few others anyway.
I'll probably have more questions, but these are the main ones that I'm grappling with now.
Thanks so much in advance for any advice you can throw my way.
Cheers
My goal:
My gear:
Head Unit:
Amps:
Speakers:
Wiring:
Questions:
Cheers
