2 amps, 1 grounding point
M@nJo
im gonna install a 2nd amp soon and would like to know if it is safe to just use the same grounding point as my sub amp for my 4-ch amp?
sub amp = 4ga power/ground
4-ch = 8ga power/ground
meaning, i will still use seperate wire and ring terminal... i will just be using the same grounding point to hook the terminal on.
I used some cheap bs distro when i grounded my amps and other acc...cuz if you run multiple ground spots,that could cause a ground loop or something to that ecstent.but as said,pick one spot n call it good.
M@nJo
M@nJo
bay area
Black_Jesus
