2 4 ohm subs and an 8 ohm sub on one amp
04Silvy
i have a few old subs just laying around and wanted to use them with one amp, but the problem is one of them is a svc 8 ohm that does about 400 rms and the other two are svc that do about 150 rms each, and i was wondering what kind of amp i need, a mono, 2 channel, or 4 channel. Which one would work the best and how should i wire it?
Brah I'm not tell him to do it or not to do it...lolol
yet if he does at lest run them (parallel)
Don't listen to anyone who suggest to run them together.
You will be far better off running 2 or the 1 or selling all and getting something else.
yes im going to build my own box. but im thinking i might just use the 8 ohm sub because its louder than the other two, and buy a cheaper 4 ohm dvc sub and run that at 8 ohms, and then find a 2 channel amp and bridge it at 4 ohms.
04Silvy
04Silvy
United States
04Silvy
