2 15s + 03-07 Honda accord
depends on recommended space etc.. also a lot of the time it has nothing to do with the actual trunk space.. just the opening.. if you can't get it in doesn't matter how big the internal volume is.. unless you build inside it
dependent on the subs. as well as it being sealed or ported. may want to face cabin and seal off trunk if the box is too big and doesnt let waves into the cabin
sealed or ported, would something like 2 HDC 15s fit?
Also in the coupe, I may be willing to give the backseats up if they are poop, and no this isn't for numbers or comps, I'm mainly going for everyday loudness and I may actually get it metered, if I were going for numbers I would try and shoot for 142-145 on music, or as close as I could get. If I can't get that then its fine. Also the backseats let down so I'm sure that would help my cause as well.
I have an 06 accord sedan. Tried to fit 1 15 in it but the box recommended wouldn't fit through the trunk opening. You have to build it in the trunk. The box was 4.5 cubes with dimensions 17Height x 31.5Width x 24depth. Had to go with 2 10s instead in a 3 cube box.
Crimson Boom
Crimson Boom
Birmingham, Alabama
Crimson Boom
