2 15" vs 1 18"
conor_thompson
So I have a old Memphis mojo 15-cm15d2 just sitting at my parents house because its blown just waiting to get fixed. Should I
A:Buy 1 18" I was looking at FI SP4
B:Buy my buddies Mojo
Mind you its going in a pretty small car, a 08 mazda3
Also mind you there are some power restraints because I'm not looking to spend more than 500-600 on an amp
if was me id go with 2 15s. more cone area, motor force, can use about the same size box as 18. thats if subs were equal. if the 18 is much better quality than the 2 15s id prolly go with the nice 18. quality over quanity.
Can you can't ignore the cone area advantage at is quite significant, about 115 square inches. That's like adding a 12" sub on top of the 18".
However in a trunk, I see no need to go that big. Two 12"s or even a 15" off a good amount of power should do you fine.
just run a single 15. your budget aint gonna work with a sp4. youll need a 3k amp, a big battery in the trunk a upgraded one under the hood a ho alternator, 20 or so ft of ofc 0g. a aq1200 or similiar goin to your mojo15... if d2.. in a good box and i would think you would be happy. really, an 18 doesnt belong in your trunk
Sorry I didnt provide the complete details. Will be taking out the back of the backseat and putting the sub there, therefore i basically have the whole trunk for just straight box and port so the box can be pretty large. The Mojos RMS at 1750 so I'm thinking for 2 I need at least 3000W. Is there anyway I could get that for around 500?
A guy in Rhode Island is doing 156's with a pair of mojo 15's in his accura. They are quite capable. I think the difficulty may be finding OEM recone kit for your broken one that will match the other one.
conor_thompson
conor_thompson
st pete, fl
hispls
