(2) 15" fi btl
ganesh134
NY
Need help with deciding on building enclosure for (2) 15" FI BTL.
This is the amount of room i would like to use but if this is not good, give me some recommendation.
Width = 36" (Max width)
Height = 20"
Depth = 20"
Would be sound better if the sub face up or sub face back.
All of this is going inside a SUV.
I can not change the width at all because of the location of the wheel.
If i move the height and depth
Height = 22"
Depth = 22"
Is that better. Just a bit over ~7 cube feet.
If the above dimension are small. What are your recommendations? The max width is 36" due to wheel. I would like to keep it under height under 24" but if i need to go higher, i would go. I will re-measures and check the max dept. I believe it is around 26 or 28"
HEHE My BTL's
I had mine in a box
45w 18h 20d subs up port up and can do a 150.0@45hz sealed on the dash!
I think I saw your youtube vid. "Batteries up under this b*tch!" haha. Skating rules! I got my board in my car at all times...you never know when you might pass by a sick spot.
Yea, sick setup you got there.
To the OP. What car do you drive where the wheel wells are so close to each other?
01 Pathfinder. I wish the wheel wells were just 6" - 10" apart. I would be a perfect setup.
Get someone to design a box with your max dimesions so you know how much you got! You should be able to give them atleast 3.5 cubes each which is what mine had.
ganesh134
ganesh134
NY
ganesh134
