carmania
Can anyone help me with the configurations of my 2 subs and the amp,,i mean,,what will be the perfect wiring method to get the most power out of the amp to the subs?
Subs are 4ohm each with 300W RMS and 1000W Peak Power
Specs of amp:
Amplifier
Channel Configuration (number of stereo channels) : 2 / 1
High Pass Filter, selectable (Hz) : NO
Low Pass Filter, selectable (Hz) : 80, -18 dB/oct
Rated Output Power (DIN 45500)
Max. channel configuration at 4 ohm (W) - 2 x 60
Min. channel configuration at 4 ohm (W) - 1 x 130
Max. channel configuration at 2 ohm (W) - 2 x 65
Rated Output Power, RMS 20 - 20000 Hz
Max. channel configuration at 4 ohm (W) / THD (%) - 2 x 60 / 1.0
Min. channel configuration at 4 ohm (W) / THD (%) - 130 / 0.1
Max. channel configuration at 2 ohm (W) / THD (%) - 2 x 65 / 0.1
Maximum Output Power (1 kHz)
Max. channel configuration at 4 ohm (W) - 2 x 110
Min. channel configuration at 4 ohm (W) - 1 x 350
Max. channel configuration at 2 ohm (W) - 2 x 175
General Specification
Frequency Response (Hz) : 5 - 50,000
Tolerance (dB) : 0 / -3
Signal to Noise Ratio (dB) : 97
Total Harmonic Distortion at 1 kHz (%) : 0.005
Others
Number of Input Channels - mono : 2
Balanced Input Circuit : YES
Dual Mode Capability : YES
Load Capability (ohm) : 2
Line Out : NO
MOSFET Output Stage : NO
MOSFET Power Supply : YES
Subsonic High Pass Filter (Hz) : NO
Speaker Level Input : YES
Toroidal Transformer : YES
Line In: Input Sensitivity (V) : 0.3 - 6
Gold Plated Connectors : YES
Current drain (A) - rated output power at 4 ohm : 15
Specs of amp:
Amplifier
Others
Line Out : NO
