2 12' MA Audio 1200XL and a MTX Thunder TA8001 amp
ight man thanks for your quick reply
here are the specs
TA81001 Specifications
# of Channels 1
Minimum Single Channel Impedance 1
Class D (Patented Adaptive Class D)
(Pat. No: US06753729) x
Amp Type Optimized for Subwoofer x
Power Supply Semi Unregulated MOSFET
(Pat. No: US05598325) x
THD + Noise (1 Watt) 0.5%
Signal-To-Noise Ratio (1 Watt) 68 dB
Overload Protection x
Thermal Protection x
Xtant Technology Cooling Continuously Variable Fan Speed x
Connection Terminals StreetWires Connectors x
14.4VDC Power 4 ? 500W
2 ? 1000W
1 ? 1500W
4 ? (Two Amps Strapped - wattage is combined power from both amps) 2000W
2 ? (Two Amps Strapped - wattage is combined power from both amps) 3000W
INPUT (RCA Connection) Low Level x
Hi Level w/ Smart Engage (Pat. No: US06556683) x
INPUT SWITCH Input Sense 100mV-1V/1V-10V x
GAIN CONTROL Mono - 100mV-10V x
CROSSOVER Low @ 40Hz-200Hz, 24dB x
SubSonic @ 20-50Hz, 12dB/oct x
EQUALIZATION Parametric: Boost/Cut +/-12dB, Freq. 30Hz-80Hz, Q 0.5-4.0 x
OTHER FEATURES Remote Subwoofer Level Control Parallelable x
Phase: 0 or 180 x
FUSE RATING Total 160
Quantity x Fuse Value 4 x 40
DIMENSIONS Width 20-11/16"
Depth 9-5/8"
Height 2-1/2"
MA Audio 1200 XL Spec
600W Rms
1200W Max
Dual 4-Ohm Voice Coils
240 Oz. Double Stacked Magnets
Mounting Depth: 8.5"
Mounting Diameter: 11.2"
Optimum Vented Box: 2 Cu/Ft
Round Port Diameter: 4" x 8"
Square Port Area: 3" x 6" x 12.75"
Optimum Sealed Box: 1.0 Cu/Ft
Tuning @ 40Hz
what about a more powerful sub, would that be better. i really dont know much about what to look for in a sub and amp. i really just look at rms
well im in the process of trying to find someone to buy my current system, which you can see in my signature, for at least 250. subs, amp, and box. i think its reasonable, and after i sell that im going to put that 250 to new subs. my girlfriend is going to buy the amp for me, and she said 300 is the most lol, got lucky with that. but my budget is around 500 to 600 bucks
hey man thanks for all your help. well my electrical system is good, and i agree that im going to need a cap, how many farad would you think i need? i never really understood farads either, but i will get a cap.
john3387
john3387
Houston, TX
john3387
