1st Midranges. Advice/suggestions wanted.
bikinpunk
G-g-g-g-g-unity!
So, I'm going to buy my first set of midranges. First off, I plan on having these play between 300-4000 or maybe higher.
Restrictions:
3"
$150 Budget
100w @ 4 ohms x 2
I have about 1 liter (.034 cubic feet) to work with.
Sealed/Vented, doesn't matter.
Music Tastes: VERY Broad. Pop, rap, country, easy listening, etc
I'm looking into the Seas Vifa TG9 right now, but it looks like they need more space than I have.
They'll be going near the A-pillar along with the tweeter.
I'd really like some suggestions here on what else I should look at. I'd also appreciate some feedback on playing frequency. My rainbows will be staying for a while, so if anyone has experience with using them as mid-bass & tweeter I'd appreciate that input, too.
If ur just running midrange/tweeter/sub then u need a midrange that plays down to around 100hz. Since a sub isnt's suppose to really play above that anyways. Good general X-point for tweets to mids would be around 3khz. Be alot better if u could run a 4 way with mid/woofer/tweet + subwoofer. That way u can cross the mid at around 500hz and run woofer from 100-500.
That's what I'm talking about.
3-way setup: I'll be running mid-bass in doors, midrange & tweeter up top. Sub in trunk.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Does it matter dome or cone?
actually it should as not too many domes can play down to 300hz. i think the atc domes and dls domes are the only ones i know of that can go down that low but thats still pushing it.
if you can get a pair of legatia mids used, i believe they go around for that price. retail is $250. tg9's are also a nice choice.
I'm not sure it matters.
It'll be mounted up top and can easily be on-axis, or off-axis. From what I understand, dome's aren't good off-axis, but that doesn't matter here. I'd like to cut it off pretty high if I can (> 4khz) but have it play fairly low. It's really all relative to the driver's capabilities I suppose.
I'm fortunate here since I can choose off or on-axis. If I HAD to pick, I'd probably say Dome, but for not reason other than I like the idea of on-axis.
Hopefully someone can embellish on the characteristics of dome vs. cone.
Wow, 3 replies while I was typing mine.
I e-mailed Scott Buwhalda (sp?) about pricing on the L3s and he said $249 shipped. That's out of my price range by a lot.
from my understanding, domes are better off-axis, cones on-axis
I know this is way way under budget, but the Aura 2"
http://www.madisound.com/cgi-bin/index.cgi?cart_id=1172329.14308&pid=102
It's a low cost alternative, and really really doesn't have much distortion, even turned up playing full range.
They don't require much power, and would be well suited to a 1 liter sealed enclosure, or IB.
Rear mount on them too, which is quite nice.
I have a pair here, and they are actually impressive
CT
bikinpunk
G-g-g-g-g-unity!
bikinpunk
Alabama
iamamp3pimp
