Model s : 16-PR1. 500
16-PR1. 1000 by MEMPHI S
FEATURES
• 1 ohm MONO stable
• Low Level Inputs & Outputs
• Variable Bass Boost (0-18dB) centered at 45Hz
• 24dB Subsonic Filter
• Fully Variable Low Pass Filter
• Protection Circuitry Against Overload, Short Circuit, Thermal, and Reverse Polarity
idk if yours is the PR or this
SC 1.500
SC 1.500
CONTINUOUS POWER OUTPUT
INTO 4 OHM MONO 280W X 1CH
INTO 2 OHM MONO 500W X 1CH
RECOMMENDED FUSE SIZE 2 X 25A
HEATSINK DIMENSIONS 10.51"(D) X 1.91"(H) X 8.66"(W)
FREQUENCY RESPONSE 3dB, 20Hz - 300Hz
SIGNAL TO NOISE RATIO >90dB
T.H.D 0.05% at 100Hz
SIGNAL INPUT SENSE 300 mV - 8.0V
LP VARIABLE X-OVER 40Hz - 300Hz @12dB/OCTAVE
VARIABLE BASS BOOST 12dB at 45Hz
VARIABLE SUBSONIC 20Hz @ 9dB/OCTAVE
