1997 Ford F150
Bosaliniee
im planning on putting my remote start/alarm in my 97 f150 probably monday or tuesday. on the12volt.com it says
door lock-High Driver's Dash Negative Trigger w/Keyless Entry
door unlock-Reverse Polarity w/o Keyless Entry
my alarm install guide has a few different options
-negative trigger door lock system
-positive trigger door lock system
-5 wire alternating door lock
-2step door unlock wire 5 wire alternating door
-2step door unlock wire positive switched door
so which setup should i use
and do i need to buy any extra equipment like i had to in my girlfriends grand am
FORD, F SERIES LIGHT DUTY, 1997, Power Lock
Negative pulse, type B, on keyless entry models. Five wire, type C, on non-keyless models, mastered from the driver switch.
The question here, do you have factory keyless entry?
If yes, use the negative trigger
If no, then you need two 12v 30amp spdt relays, and you will have to do a five wire
Bosaliniee
Bosaliniee
Fort Wayne IN
Bosaliniee
