1996 Toyota Camry LE - Rampage CD Player
  • 3
shackrock
alright, so i took out my in-dash (dealer) tape player....and all went fine.
I got a Rampage CD-player, which was easily mounted on the toyota's rack...
now here's the difficult part - which wires go where.
i ended up putting the switched 12v and the constant 12v (from rampage) BOTH on the one "hot" wire coming from the car...and clamping them together.
ground wire with the car's ground.
and i seemed to get all of the speakers in correctly.
first off, i have a bunch of left over wires - on both ends of things (1 from hte rampage if i rememeber correctly.....).
-my camry HAD a moveable antenna - but that broke a long time ago, and since then i now have an "always up" antenna. (assuming one wire is for that)
-my camry's clock will NOT work anymore...so i assume that is one of the wires as well.
-my light (car's light, on the roof) will not work anyomre, no matter what. But sometimes i can here a light "buzzing" sound when i flip the light switch to from off to on (or vis versa)...as if the car is trying to turn it on or something??..i really have no idea, but it remains there until i flip it to off again.
-my headlights/tail lights stay activated after you turn the car off - UNTIL you open the door driver's door. Or at least that USED to be the case! Now, as soon as i power the car off, the lights go off as well. However, when i open my door, i can still here the usually "click" that turns the power totally off, i'm assuming. by the way, i can still use windows until the door is open - just the light function no longer works that way.
alright, so now that i found all my problems, anyone know how to fix this? can somebody direct me to a webpage that lists what each wire in this specific model is for, etc. etc.? lol.
and while i'm at it - the cd player randomly "mutes" for .5-1 sec often while i'm driving. Kind of like a skip, but more of a sound stop for that length of time. Do you guys think this is a wireing issue as well? or just a crappy rampage 100 dollar cd player....?
THANKS. if anyone can give me ANY information on how to get started here...well, i'll love you. lol.
well then learn what all the wires are first before you just start connecting things....there should be a separate power and acc. power wire...not just one....then a ground...and usually 8 other wires for speakers and then one more for a remote wire/ power antenna wire....other than that the other wires probably shouldnt be used...as for all your other problems....sounds like your having car problems......i would take it somewhere and get it checked out
which leads me exactly to my problem. these things all worked fine before the uninstallation of the CAMRY TAPE PLAYER.....
isn't there a website of somekind which tells in details about all the wires of specific car units??
Check the manual that came with the rampage it should have a diagram of the wires and the harness that came with it. Go to any store that sells car audio equipment, they should have a harness that directly attaches to the toyota harness and you can just connect the wires that way. I just did my '96 4Runner 2 months ago, was a piece of cake. Good Luck.//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
6
231
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
Hey everyone! I'm a car stereo newbie and I know next to nothing about car stereos, only features. I recently purchased a 2010 Toyota Highlander...
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
9
152
shackrock
shackrock
Cinti, OH
bebebloo
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
