18" FI Q Enclosure
farmerehsan
144.6 db
Hi i need some help to make a box, i kno nothing about it.
I have a nissan xterra 2004 dimenions 3x2x 1.5.
i would liek to use the smallest box possible according to the knowledgable on here.......
Q18
DUAL 1 | DUAL 2
Fs: 24.5 Hz | 23.8 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 5.66 | 5.73
Qes: .64 | .63
Qts: .58 | .57
Mms: 322g | 342g
Cms: 0.13mm/N | 0.13mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 268 l | 268 l
Spl: 89.7dB 1W/1m | 89.4dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: 4-8 cuft
Ported box: 6-10 cuft @ 28Hz
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 10.000”
Displacement: 0.24cuft
can i do a 6 cuft box? a 2 x 2 x1.5?
any help thanks
First, if the box is 2' x 2' x 1.5', then its not going to be 6 ft^3. Displacement of wood/sub will make it smaller, especially if you want it ported (you have to then take into account the displacement of the port as well).
edit:
Is 3x2x1.5 your max dimensions? Every inch helps, and if those are your dimensions you will probably be able to barely fit a 6 ft^3 (internal) ported box into your trunk.
With those measurements, using 3/4" MDF (which is recommended), the max gross space you can get is 4.83... which is barely enough for sealed... and when you factor in the sub's displacement, you're left with a measly 4.59 cuFt.
I say either get more room, or get the 12, or 15.
First, if the box is 2' x 2' x 1.5', then its not going to be 6 ft^3. Displacement of wood/sub will make it smaller, especially if you want it ported (you have to then take into account the displacement of the port as well).edit:
//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif @ your avatar
send me fullsize pics...now!
farmerehsan
144.6 db
farmerehsan
Tampa
Rashaddd
