Sold 18'' Atomic APXX F/S no trades cheap
tonyrms
275 shipped had it for almost 2 yrs sub has been broken in. it weighs 75lbs and is a pretty good sub it takes 8 gauge speaker for the terminal so its time to sell it im getting out of car audio for a while
Oh and by the way it's an apxx series
sub specs:
Super eXTREME SPL competition woofer
* high sensitivity, extreme efficient motor to ensure high SPL possible
* Rigid Die cast aluminum basket
* Organic long fiber non-pressed cone body for accurate tight bass
* Highly damped Kevlar and carbon fiber reinforced cone body
* triple layers foam surround increase the power capacity of woofer
* Extended neck joints on cone, coil and spider strengthen the integrity of moving structure for high power capacity
* Compressed mounting ring gasket
* vented coil for extra heat dissipation
* 3 inch high temp aluminum voice coil
* extended, machined cut one piece back plate
* Powerful double stacked high energy magnet
* over 2-1/2 inch long excursion motor structure
* reinforced resin impregnated polycotton spider extend the life span of the speaker from material fatigue and collapse.
* integrated heavy duty lead wire on spider prevent short circuit and melt down
* dome shape dust cap design
* low carbon front and back plate
* Vented magnetic gap technology
* Laser etched, machined and chromed back plate
* handle up to 30,000Watts in 3 second short burps
* custom matching impedance to amplifiers
tonyrms
tonyrms
Shreveport, Louisiana
tonyrms
