16 Volt 1500 watt amp
1 Audiopipe AP15001D Mono Class D 16 Volt Amp
Product Features
600 x 1 RMS @ 4 Ohm, 950 x 1 RMS @ 2 Ohm,and 1500 x 1 RMS @ 1 Ohm
1 Ohm load stable, Input level: 0.2-5v, Bass boost frequency: 30-80h
Built In Variable 12 dB/ Octave Crossover, Low pass filter: 40-180hz,Subsonic filter: 5-50hz
Bass Boost 0-12dB, Distortions:
Dimensions (WxHxL) 7" x 2.5" x 16" Item Weight 11 Pounds
like new used only a couple weeks so far
$350 OBO or trade for similar Class D 12 volt amp Must be 1 ohm stable
Local only( Hampton Roads,VA ) no shipping
Thank you for the input. This is what was paid with shipping. I am willing to negotiate on the price. I would rather trade then sell it. But it is OBO. I started my build but a family emergency came up so the funds to continue are not there now. I really just want something that doesn't require the upgrading that a 16 volt amp requires.
I do have it running at 16 volts. 16 volt racing battery to 4.5 farad cap rated to a 20 volt surge to amp. My 16 volt charger got wet when my hot water heater exploded and ruined it so now I can not charge up the battery and do not have the funds for my mechman alt.
yea im not trying to post dump bump, but if you really paid that much im curious to where you got this amp from? because getting these new doesnt cost close to what you paid for it
I do have it running at 16 volts. 16 volt racing battery to 4.5 farad cap rated to a 20 volt surge to amp. My 16 volt charger got wet when my hot water heater exploded and ruined it so now I can not charge up the battery and do not have the funds for my mechman alt. Those less than $200 are the mini amps.
actually the ap1500's are also under $200. again who charged you that much for that amp? How long ago did you buy it?
DELTETE PROFILE
Los Angeles,CA
bgowdy
