15's & 18's
chevy454
LA
i THOUGHT about doing a wall or none wall enclosure in my car with three 18's of four 15's...does 18's have the same accuracy as a 15? i know it will play deeper because of the cone area..and yes i did search
18's are big, slow, and can only play from 50 hz down.
if you try to play rock music through them it will clip your amps //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
omg.
All of these answers are wrong.
The only thing that dictates an answer your response is based on the motor of said "15" or "18."
They are not inheritly slower, or hit harder.
They have the ABILITY to hit harder, it doesn't mean that they do. As said before, it all depends on motor design and power.
This thread is dumb.
Since you're doing a wall and should have plenty of room I'd do a 10, 12, 15, and 18 to cover all the freqs. Should be very accurate and hit the lows nicely also. Might even consider running 4 diff brands of subs for that extra pimp look....
Definitely. You should run a DD, FI, AQ and RE.
you forgot the 13.5 lol
LMFAO:laugh:
chevy454
chevy454
LA
IbSlamn
