skmfkr
yeah ive always heard colder means better numbers, but mine seems to go down even sometimes when i meter at nite it seems lower sometimes
Well you had them in diff spots if you had them in the car at the same time...unless youve learned how 4 objects can exist in the same space n time at onceWRONG. A TL can be adjusted just like a AC. And We have had 4 tls in the same car at the same time, and had different db readings. like 1.2 db off was the maxiumum.
You can only adjust the termlab when it's not reading.WRONG. A TL can be adjusted just like a AC. And We have had 4 tls in the same car at the same time, and had different db readings. like 1.2 db off was the maxiumum.
IASCA also uses the a/c 190, which is a much more accurate and consistent meter. But, as with the a/c 180, it can be adjusted as well.Ya I was just saying from my expierence. I was down at Florida finals. IASCA was there using the A/C and DB drag/Bassrace was there using the T/L. Everyones score was 2db's less on the IASCA mic compared to the T/L
Can i please see your set up for your sig? pm them to me.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifwhy yall need proof that is not a impossible number to hit wit that setup.... good number though...
I'm sure he means pics of the install. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifi don't have any pics of it but i seen some on here from finals... john carr put them on here of my car ... i think the thread is usaci finals pics or somethng like that...
oh my god its you!Even though the air is denser in the cold, maybe that doesn't compensate for the air being more energized in the heat.
The hotter the air is, the faster the air molecules are moving. so maybe its easier to move molecules that are allready moving?
then Again maby it's just cause you put you're windows down when it's hot //content.invisioncic.com/y282845/emoticons/nutkick.gif.acc8dcd6c1bd27fba0cbeda5b212085c.gif
on the TL or what? windows shut? windows down? mic on the dash? on the floor? headrest? IN THE PORT? lolMy buddy in high school did 148.9 in his Accord with 1 Orion XTR15 DVC. It was in a bandpass running off an XTR2150. Its not impossible to achieve something high like that.
