Rich B
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
The first of the new products to be released in early 2009 are:
1) Two channel amplifier rated at 250w/ch 4 ohm/500w/ch at 2 ohm. This amplifier shall be able to multi task. It will do the duties of a traditional 2 channel amp with High Pass, Low Pass and Band Pass functions. In addition it will do what traditional mono block sub amps do.
It will have loop through outputs for daisy chaining multiple amplifiers. The loop through sockets shall be the 3rd and 4th inputs for constant subwoofer fading
The amplifier shall be small and light and very efficient. A radically new power supply design is being employed in all our new amplifiers
2) A six (6) channel amplifier rated at 150w x 6 @ 4 ohm/ 300w x 6 @ 2 ohm. This will truly be a multi tasker as the options available will be really versatile. Full range, High Pass, Low Pass, Band Pass and sub modes are offered with the ability to have all channels as sub, 4 channels or just two.
So the amplifier will do 150w x 2 flat, high pass or low pass (mono or stereo) on channels 1+2.
Channels 3 +4 will do the same with the addition of the Band Pass function.
Channels 5+6 will do full range or Low Pass (mono or stereo) with a variable subsonic crossover.
You are able to:
* Run all channels in flat mode
* Run Ch's 1+2 High Pass or Flat and 3+4+5+6 in Low Pass
* Run Chs 1+2 High Pass or Flat, Chs 3+4 High Pass, Band Pass or Flat and Chs 5+6 Low Pass
* Run all channels Low Pass
* Channels 5+6 can have 2 or 4 RCA inputs
* Channels 5+6 can have their Low pass crossover deleted when used with head units having built low pass crossovers.
* Run all channels flat
* Run all channels low pass
* Pairs of channels are bridgeable for 600w 4 ohm operation for a total of 1,800w - many guys prefer to run their woofers from separate channels as it makes impedance mixing/matching easier.
Example you have THREE 4 ohm woofers. What do you do? Run them in parallel at 1.3 ohm = tough load for most amplifiers (Ever compared the sound of a nominal 1 ohm sub to that of a 4 or even 8 ohm sub - the 1 ohm sounds really bad!
Solution with this or the two channel amplifier. Run two woofers in parallel on one channel and the third on the second channel when using the 250w/ch amplifier OR simply do the same with the 6 channel amplifier with a bunch of channels to spare OR run each woofer on a pair of bridged channels with 600w to each woofer.
Need I say more the permutations or huge and with a little imagination one can accommodate almost every requirement with the 6 channel amplifier.
A four channel 100w x 4 is being considered as well.
http://www.zedaudiocorp.com/products.html
//content.invisioncic.com/y282845/emoticons/drool.gif.b5e863e893038027711d4402f340dad0.gif
You are able to:
