150 db
One more question? What size fuses do you use the biggest i've seen are 300 amp anl fuses.
Depends on your wire rating.
I run KnuKonceptz CCA 1/0 that is rated at 250 amps at a 20' run.
I have a 250 amp circuit breaker and running a 13' run to my rear battery
From alt to front battery is a 4' run and I have a 150 amp breaker on it.
I was thinking a Q1-3500d.1 or two q1-2200d.1's strapped on four TNT 12's. Will that be too much for them?
Sure you have the room to run an 8 cubic foot net box in the truck??
Pretty sure they are rated at 600rms and only come in D4s from what I see on ABs website. You are going to have a final ohm load of .5 or 2 ohms. So 2 2200s strapped at a 2ohm load would work but its quite a bit more power than you need.
It's a sedan not a truck and I've been told they are similar to sa 12's so they can handle close to 1000 watts and I don't know if i can do 2 cubic feet each I might just have to get a truck or I can invert them and I don't wanna get rid of of my TNT's (sigh) //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Lol really? My boy has 2-15s in a marquise on 5k doin hairtricks like nothin
Oh and his is a no wall , simple ported box built solid
Thats a good bit of cone area and a lot of power. I mean that two 10s need alot of power ever 2 12s
It's a sedan not a truck and I've been told they are similar to sa 12's so they can handle close to 1000 watts and idk if i can do 2 cubic feet each I might just have to get a truck and I don't wanna get rid of of my TNT's (sigh) //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
The tnt 12s can only wire to .5 or 2ohm when 4 are used they really need 2.25cube each but will work down to 1.75cubes each. 2 q2200.1 would be almost 5k of power if you had the 3lectrical to back it. The tnts will handle this fine for short burst but for daily I would turn the amps down.
If you have a decent ported box tuned low you should pull a hairtrick pretty easily but hitting a 150 will be alot harder
As long as I can do some hair tricks I'm good and how low? Like 30-33 hz? What other strappable amps would bring me around 4500 watts?
16 H, 36 W, 34 D that gives me about 9.41 cubic feet before sub & port displacement.
Correct but is a box that big going to slide in the truck opening? I had such a hard time getting my 4 cube net box in my trunk.. //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
Not going to be able to get 4 12s firing forward + port with only 36 wide and 16" tall.
Honestly I would do 2 ZV4s on 2 2200s or a 5k firing forward sealed off.
Jerm1400
Jerm1400
Orlando, FL
winkychevelle
