$150-300 Comps in Kickpanels.
drzenitram
If you're familiar with Q-Logic kickpanels you know that they're flimsy and are not enclosed. They have a wide open back. Also, they only fit 5 1/8" speakers with grilles. I've heard you can fit 6 1/2" without grilles which is something I might end up trying.
I currently have Rainbow Dream Line 5 1/8" Components. I'm running them on 100-125watts from a Nine.2 amplifier. They aren't as clean as i'd like them to be, there's literally no midbass, and they don't get as loud as I want them to.
I backed them with a few layers of sound dampening and a 1/4" mdf ring and stuffed them with polyfill. It didn't seem to help much, but I'll do this with the next set of components too.
So, for my application, what should I get? They're paired with a Diamond M6 MKII 10"d2 on a Viper 1200.1 currently @ 1 ohm.
i got RE components (6.5" midbass and 1" tweeter) onto my q-logics... just mount the mid on top of the indent with longer screws, doing this also shallows up the mounting depth. i get decent midrange from this setup but i am running 75w at them, they're rated for 50w. mine only have the supplied polyfill behind them, no deadening done; they rattle pretty bad when the mids get loud enough to massage my feet.
D@mn only 215w each side //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
pffft, I figured will all those amps they have laying around there in stillwater, he would be running at leask a couple of kilowatts to his comps, your letting me down polecat, your letting me down //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Well, but I don't have 215 watts. Does anyone have reccomendations for speakers that work well in kickpanels, non-sealed that will produce good midbass in a 6.5" size and also get pretty loud on 100-125w?
couple kw to comps ?? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif THat's some frekin head room right there. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Pg octane zr's will slam the midbass, and get loud. They may be something you should consider.
drzenitram
drzenitram
Wichita
AcidicDreams
michigan born
    May 14, 2026
michigan born
    May 14, 2026
