15" hdc3 or MMATS juggernaut?
what sub
  • new HDC3
    Votes: 12 75.0%
  • used MMATs Juggernaut
    Votes: 4 25.0%
  • Total voters
    16
which one would be louder?i know the coppers are knows to have alot of ohm rise..
Copper HDC has less rise/is more efficient then the alum coil version. Meaning it will get louder off less power //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Obviously once you get to a certain power level the copper will reach thermal or mechanical failure, at that point you want alum coils....
and I'd get the alum coil for a 2200 running at .5ohm assuming this is a daily set up. For burps only you'd be fine with copper.
4.5cubes if you can fit it and lots of port area 16-20^2 per cube...
box right now has 16.6 i will see if i can bump that up.
after rise it should be right around 1 ohm tho.. so would the extra $60 for alum coils be worth it? or should i get coppers and if i break them then recone to alum?
uGotF-ckedUp
uGotF-ckedUp
platte south dakota
uGotF-ckedUp
    Jun 15, 2024
    Jun 15, 2024
