14 RMS vs 22 RMS
raptor77
Canada
Hi,
I bought a Pioneer DEHP8400BH but it says it's 14 RMS on the box and it doesn't mention the 22 RMS like on the website.
I'm thinking to return it for a Alpine (CDE-133BT) since I don't need HD radio and all that stuff since I'm in Canada :p.
Although, why the other brands (like kenwood/alpine) says the output of their head units are 22/18 RMS? Is it CEA 2006 certified also?
Thanks,
The 22rms for the Pioneers is the rated power @ 5% thd. The 14rms is cea certified though. Check out the manual online and it'll be in the specs.
None of those make their rated power. And you won't hear the difference between that power anyways. They'll all make around 10w or so. And for future reference, the CEA certifications are inapplicable and relatively worthless.
ok then whats the point????
Those few watts are not really a worthwhile reason to switch your headunit.
Get a headunit with the options that you want & get an amp as mentioned. Even a small amplifier will make a world of difference when compared to headunit power.
Alright, If I do get an amp then where do you suggest I install it? My car is a hyundai accent 2010 hatchback. There's almost not much room.
edit: recommend me an amp (best quality/price) budget: 200$~
Marketing sir. To sell more products to uninformed consumers.
Alright, If I do get an amp then where do you suggest I install it? My car is a hyundai accent 2010 hatchback. There's almost not much room.edit: recommend me an amp (best quality/price) budget: 200$~
I'd say under the seat. But I think just upgrading the head-unit will be a nice enough upgrade. If you change out the speakers to something decent, then I'd say get an amp. Regardless, a good, affordable, small-footprint amp that I would recommend is the PPI Phantom 900.4. : Precision Power PPI P900.4 (p9004) 4-Channel Phantom Car Amplifier
These things have been going out of stock non-stop since they've been released.
I'm curious about this.. would you mind explaining why?
Well they might make 14 watts when turned up to maximum volume. But then you'd have a TON of distortion and likely clipping as well. I'd say you probably have around 10w of clean power. Regardless, you're not going to hear the difference between 10 and 14 watts. And you're still getting more power and cleaner power than your factory head-unit. I wouldn't worry about "power" on an aftermarket head-unit. That's not what it's for. It's there for cleaner signal, more features, more sound control, and more upgrade options.
yea you would see 10w rms from a hu at most. likely less. if you dont plan to upgrade speakers etc then why not use stock hu? idk what year your car is but most newer cars have decent stock sound and likely steering wheel contols, voice controls, nav etc. could be costly for the install kits as well. if its old then i understand and wouldnt worry about what the output rating is. they are all about the same. like said just stick with the pioneer.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
873
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
896
Deff a beautiful constructed sub. The best thing about as well, they do perform very well too and have excellent C.Service and even Tech service...
21
raptor77
raptor77
Canada
zako
slater
    May 2, 2024
slater
    May 2, 2024
