xterra02_pat
Ok, I have 1 13w7 in a sealed box. Which way shoould I wire it? Series or Parallel?
Agreed 100%what amp do you have?
his sub actually reads dual 1.4 on a DMMAgreed 100%
The 13W7 has dual 1.5 Ohm (rated - a DMM may tell a slightly different story) coils, correct?
If so that can give you either a .75 Ohm (parallel) or a 3 Ohm (series) load. With that in mind which is more appropriate for the amp you're going to drive it with?
Which would be why I made a remark about 'rated - a DMM may tell a slightly different story.'his sub actually reads dual 1.4 on a DMM
