If the subwoofer is a dual 4ohm subwoofer, then it can be wired to 2ohm and to 8ohm.OHHH ok. That makes a helluva lot more sense thanks.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif (not being sarcastic)
one thing though...The CMPX215 has 1600 Watts RMS Power Handling @ 2 Ohms Dual 4 Ohm Voice Coils sooo...the power handling already kinda states what it needs right?
If the voice coils are wired in series it will. if in parallel it will be around .7ohms- dangerously low I think.The 13W7 is dual 1.5 ohm coils. Your amp will see a 3 ohm load so the amp will be fine.
After impedance rise, it isn't any more dangerous than a 1ohm load.If the voice coils are wired in series it will. if in parallel it will be around .7ohms- dangerously low I think.
Damping factor of 10-20 is sufficient. Going any higher won't yield any increased audible benefits.I don't run mine that low, but then I like damping factor.
Yes.Soo can he run the 13W7 off of 1200 watt X 1 @ 2 Ohms RMS?
