12w6 vs 13w6
well i feel like i'm not giving you enough credit for your arguement because are partially right about some things, but you are completely missing the point you are agrueing about something completely different than i am... your argueing about how a longer excursion helps the sub be linear and you are right about that.... but your not paying attention to a couple of facts...
first of all distortion allways exists unless you are in a vacume with all perfect equiptment and no interference of any kind... lower amplication only makes it less audible just as it makes the music less audible... but it's still there....
second (this is a important one)... A VOICE COIL'S ABILITY TO CHANGE ITS CURRENT GETS FASTER AS THE POWER INCREASES... i don't understand how someone who is apperantly so knowledgeable about audio doesn't see this
here's where your point comes in.... as the power increases the sub also gets less linear because in effect every time the sub reaches it's "resting point" it is, in effect, thrown to its excursion point in this part of the phase as the sub goes further and further out from the center the coil loses more and more control makeing it less accurate... the fact is that the 13w7 has the ability to hit full excursion and still sound somewhat decent and have an on the map SQ reading
but as you decrease power transient responce gets better untill you get to 1000watts where sq decreases not having anything to do with to do with excursion or hom the suspension is designed but because the speaker requires a specific amount of power to reach maximum sq now
now a point that you haven't said but i believe you might understand is that the reason sound quality usually doesn't decrease at lower levels is because... as the coil's ability to contribute its "current magnitude-forced transient responce" decreases, motor gains control raising the transient response. but underpowering is different than turning the volume down... jl amps are recommended to put out a specific output voltage and the subs are designed to recieve a certain voltage... this amount of voltage is regulated by the amp to make the change in volume by the source... to not interfere with sound quality and to give a balance of sound(so the volume of the substage increases and decreases at a comparable level to the frontstage) but all of this is set from a reference level predeterimined by the amp input, amp output, sub resistances, sub efficiency, and many other factors, but subs aren't as flexible in application as most people believe.
(((((PAY CLOSE ATTENTION TO THIS PART...))))) a 500/1 will never be able to power a 13w7 and give a flat responce because for you to reach half of the subs input/output potential you must set the amp to full gain... with that said an amplifier works exponentialy multiplying the signal input,
turning the gain up raises how much the input is muliplied...
so a sub that is useing half of its potential but the full potential of the amp will have far more noticeable distortion because if the distortion is at a higher amplitude than the music input, which it almost allways is, the distortion will be amplified more than the music is....
quote edit: i know that is not exactly how it works, it acutually doesn't change how much the amp is amplifying but only how powerfull the input is... but the effect is still the same
heres an example: lets say you want a 13w7 to run at 250 watts at maxium potential this will give you horrible sound quality with a 250/1 because gain is set on maximum... but possibly good sound quality with a 1000/1 set to a level of 25% which should give you about that 250 watts you were lookin for but there is another problem... 25 percent of your system's volume is reaching your "maximum sub potential of 250 watts... solution? smaller substage.... your front stage should be able to keep up with your subs maximum potential at all times, other wise you are forced to underpower your subs... or use some kind of attenuatore on the input of a lager amp to retain the same quality at a lower level... you simply can't underpower your subs (!!!!!!you HAVE to have a amp powerfull enough for at least IDEAL output inorder to retain sound quality at lower levels!!!!!) i say again you can't underpower your subs and get good sound quality!! some of those people who have big subs in their car have big subs that handle less power or they have BIG powerfull amps the fact is ....
the fact is that 2 amps pushing the same power one at 25% one at 100% will not produce the same quality... so yes! the 13W7 REQUIRES 1000watts to have the best sound quality at all volume levels ... if the 13w7 is too loud for your SQ if you want to run 500 watts get the 10 or a lesser series you just can't underpower a sub and get good quality
you **** at life. that is all.
thanks fer the intelectual comments all i see your a reference for the guy below me... doesn't suprise me considering you both don't seem to know how to do anythink but tell people they are wrong unless they agree with you... leaving out the small little thing that makes any of your agruments valid... the proof! your right! that is all i get from you ignorant people.... a "you **** at life"... people say i don't pay attention to the posts thats because they consist of the statements like the above. noone has told me a valid reason for why anything i've argued about is wrong, they just say i'm an idiot or i **** at life... well if some of the people on here think i **** at life i'm glad i do because your definition of a life is SAD to say the least
You have been given countless reasons why you are wrong by people who are much more knowledgeable and have much more experience than you. The fact that you CONTINUOUSLY choose to ignore everyone who disagrees with your bullshit makes you the ignoramus. People like Rick simply get tired of telling you the same thing over and over, and so make a short jabbing response as exhibited below. I however never tire of an argument, and will continue to tell you what an idiot you are until you actually take some time and learn a few things. I find it extremely hard to believe that, in your whopping 18 years on this planet, you have acquired more experience than anyone else on this forum. (I realize I'm only 19, but I'm only claiming to know more than YOU at the moment)
learn how to spell big words before you look any dumber...
Perhaps he should start small.//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Please read your thread on different sub sizes and everything I tried to do to help you realize how foolish you were. You asked for help/input, it was given, and you ignored it. There's no point in you ever making threads asking questions, because unless someone gives the answer you were expecting or hoping for, they're wrong. And please respond to my earlier post in this thread, douche.
dude the different size subs work... it may be impractical because of price but they work and do give you a better sound quality when set up right! i went to my friend at freemans and he did an oscilliscope reading, guess what it showed? harmonic distortion was at levels as low as any same sub setup! and well under acceptible audible levels... looks like all the trash talked in the other thread was useless and incorrect... the other thread however is of no consequence to this one where no one has told me anything i've said is wrong, and if they have i've asked why and presented a reason that i believe i am right... all you people do is attack me personally... maby i'm mistaken but i thought this was a car audio forum, not a spelling test... furthermore if you really were interested in car audio you would either give an intelligent objection giving reasons for why i am wrong, not just saying "you're wrong!"... or not post at all.... why would you waste time posting insults to someone who is "an ignoramus, or an idiot" don't you have better things to do? maybe not i guess your another one of those people who mindlessly sits at the computer all day finding ways to imagine yourself as better than everyone else... insulting anyone who doesn't agree with you... well guess what i'm not one of those people i'm here to actually learn something about car audio dipshit! you say go learn something and then come back? why the **** do you think i'm here in the first place? do everyone a favor if you don't have a reason why i am wrong just don't post, i don't need idiots who have no lives spraying shit all over my life cause it makes them feel good... seriously!... just stop and grow up
well considering that that seems to be the only input i get from you.....
I've already worn out my keayboard enough arguing with this kid. He'll just continue to ignore any response that does not go along with what he thinks, whether or not they give reasons (as many have). So let's just make this short and sweet.
//content.invisioncic.com/y282845/emoticons/ban.gif.ce8465566702ef9f72e97e794ed1c86a.gif
dude do you have mental problems? you say you've worn out your keyboard argueing with me yet you still post another pointless idiotic statement... why don't you, before you post, think about why you are posting? if its just to flame save your time with me i'm sick of your shit... you don't even have to read the threads if you don't agree with them now do you? stop being stupid
lets try this one more time..... you cannot underpower subs and get a good SQ... if you want to, ("!with a amp that has the right amount of power to achieve maximum desireable output!"), you can set the gain lower to achieve better sound quality at perhaps a lower output... but you cannot put a lower powered amp on the same sub and achieve the same effect... anyone dissagree?
RandyJ
RandyJ
USA
squeak9798
