12v-14v?
When the car is running, the electrical system is running at 14v. But when the car is off and play your system without the car running, you will be playing it at 12v.
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif Most car batteries have a standing charge of around 12.5vdc (or thereabouts) but when the car is running the alternator will put out between 13~15vdc (depending on your particular voltage regulator) and gives you the higher voltage than when the engine is off.
k, so when i have my car running it will putout 14v. i was wonderin cause i am goin to get 2 apline mrd-m605s and it says 400w at 12v and 600w at 14v. so this amp will put out 600w when my car is running and 400w when it isnt?
It depends on your particular vehicle. Some cars charge at 14.4V, some at 13.8V...some even lower than that.
That power is also assuming your car will not have any significant voltage drop //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
But yes, in an unregulated design such as that, the amplifier will output more power with a higher voltage input. Which means more power with the car running, and less power when the car's off.
But even then..the difference between 400w and 600w is only 1.7db...which is not a big difference to the ear in all reality.
spaz0055
spaz0055
Cumming, GA
05reverb
BP1Fanatic
BP1Fanatic
