12" TC Sounds TC2+ / e12O.44
ciaonzo
TheContinental
11,703
76
WI
TC Sounds built Elemental Designs e12O.44 (D4)
Great used condition, very well taken care of. Does not need lots of power, 600-800 tops. Awesome sound quality driver with lots of clean excursion. Plenty of output and great looks.
T / S Parameters
Qts : 0.49
Qes : 0.57
Qms : 3.56
Vas : 54.88 L
Sd : 0.0465 m^2
XMag : 18.3 mm
XSus : 21.1 mm
XMax : 18.3 mm
MMd : 165.38 g
Fs : 28.63 Hz
Bl : 11.36
$200 shipped, CONUS.
UPS
How does the TC2+ compare to the TC9? I am not very fluent in the TC langauge. Lol.
Wouldnt happen to have any soundsplinters lying around would you?
How does the TC2+ compare to the TC9? I am not very fluent in the TC langauge. Lol.Wouldnt happen to have any soundsplinters lying around would you?
A TC2+ is the low distortion 2" coil motor found on your TC1000/EPIC/SoundSplinter RL-i drivers, likes the 400-1000w range. The venerable TC9 is, of course, the low distortion do-it-all 3" coil motor found on so many drivers through the years, including the TC2000/OEM12/REVO/HCCA/Eclipse... So many others. Likes the 800-2400w range, depending on the build.
Awesome, really appreciate the knowledge. A TC2+ 10" should fit my build just right.
Yep, no problem.
I did have a TC2+ 10" listed but it sold pretty quickly. If you don't end up finding one, I have a couple TC2+ motors that you could build up into whatever you want.
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
629
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
    May 31, 2024
    May 24, 2024
