12" TC Sounds TC2+ / e12O.44
ciaonzo
TheContinental
TC Sounds built Elemental Designs e12O.44 (D4)
Great used condition, very well taken care of. Does not need lots of power, 600-800 tops. Awesome sound quality driver with lots of clean excursion. Plenty of output and great looks.
T / S Parameters
Qts : 0.49
Qes : 0.57
Qms : 3.56
Vas : 54.88 L
Sd : 0.0465 m^2
XMag : 18.3 mm
XSus : 21.1 mm
XMax : 18.3 mm
MMd : 165.38 g
Fs : 28.63 Hz
Bl : 11.36
$200 shipped, CONUS.
UPS
How does the TC2+ compare to the TC9? I am not very fluent in the TC langauge. Lol.Wouldnt happen to have any soundsplinters lying around would you?
A TC2+ is the low distortion 2" coil motor found on your TC1000/EPIC/SoundSplinter RL-i drivers, likes the 400-1000w range. The venerable TC9 is, of course, the low distortion do-it-all 3" coil motor found on so many drivers through the years, including the TC2000/OEM12/REVO/HCCA/Eclipse... So many others. Likes the 800-2400w range, depending on the build.
Awesome, really appreciate the knowledge. A TC2+ 10" should fit my build just right.
Yep, no problem.
I did have a TC2+ 10" listed but it sold pretty quickly. If you don't end up finding one, I have a couple TC2+ motors that you could build up into whatever you want.
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
